Hey guys,
I'm having this super annoying problem at the moment. I downloaded MacTCP, and when I try to drag it into my Control Panel, I get the message:
"You cannot move MacTCP to the folder Control Panel, because an invisible item with the same name already exists in this location"
Is there a way for me to unhide this invisible item? Or to delete it or something? I have tried searching for "MacTCP", but nothing is found.
When I try to run MacTCP from another folder, my whole system freezes, so apparently I can't do anything until I have solved this problem.
Any advice would be much appreciated!
CM
CM
