I seem to be having some sort of technical issue with a IIvx someone recently gave me and trying to install a BlueSCSI. I have a one gigabyte hard drive image on an SD card that I’m trying to use with the computer. The issue is when I use a BlueSCSI connected to the back of the machine. I have no problem with the computer, recognizing the image and booting from it. When I try to use the same SD card in an internal BlueSCSI nothing… The activity light just flashes. I’ve tried unplugging the internal CD, I’ve tried changing cables, nothing seems to work. I even swapped out the internal BlueSCSI for a Zulu - same result. Any advice would be greatly appreciated. I’ve used a dozen of these units in the past and have never had this issue before.
