My Iicx seems a bit dead. I got it to power up a couple times today at random. But now it just clicks. Via switch in back or keyboard. I pulled the supply and jumped the 5v trickle (and it did read 4.97v), same thing. In fact, with it jumped it does the same thing when installed. If I hold the keyboard power or power switch it just clicks non-stop. So pretty sure I ruled out the logic board. I do not have another supply to try.
I did leave it unplugged for a while, then plug in and try to boot right away. No go. Left it plugged in for a long while, still no-go. There is no PRAM battery, I do not have a good one to put in. But it seems like it should still boot.
Guessing the power supply will need a re-cap, which I am fine with, but I am wondering if anyone has nailed the exact issue. I will keep tinkering and take another look at the power supply. I did already check for cold solder points, etc. Its very clean and "appears" okay less the complete crap job done in the first place.
