Idea: Reverse engineering dual 1GHz G4 card
Well, since I have a Dual 1GHz G4 card that doesn't seem to work anymore, I may have thought of the idea of recreating such a PCB to allow those to build new cards with the right components. Such a thing would be difficult, but this is merely an idea. If someone wants to take on this task, I could probably provide the card.
Well, this idea didn't necessarily take off since these cards haven't even had schematics leaked for them.
However, I do have 2 cards now, one working in a system, and one dead from a failed overclock attempt (which was why I bought the Circuitwriter pen, and that worked wonders ever since!)
I also have information regarding overclocking these cards. The ones I have were very early in production, pretty much right when the PowerPC 7455 was put out to manufacturers. I have recorded date codes of 0202 and 0206 on my 2 cards respectively. I'll be calling the working card "0202", and the dead card "0206" from now on with the post.
0202 only got to 1.07GHz as did 0206. I attempted to try 1.2 on 0206 again, but that led to possible electrostatic/heat damage from the soldering iron.
I'm going to try saving 0206 again as I am learning to do BGA soldering. I have a couple of XC7455A chips on the way, too.
0202 I am leaving stock with a 66MHz boost in speed.
If anyone has tried or has the guts to try 1.2GHz or 1.07 on a dual 1GHz G4, get the CPU date code. I'll try putting some of this together to determine which ones can go to 1.2 and which ones can't.
Not too much of a speed boost, but at least you won't be dealing with the MDD's potential issues. :)
I've been planning to recreate these cards for quite some time, as well as eventually doing the entire G4 Quicksilver logic board! I've already started assembling a BOM for the LB. Once I've tracked down a dead dual-CPU card I'll probably get to work on it fairly quickly. The idea for the CPU card would be to design something with pads for two G4 7447s or 7457s. It'll be quite an undertaking but I think worth it in the long run.
