I pulled out my power supply to clean it up a bit underneath, and I decided I would try to add an 80 conductor cable to my G3. However, I found that the connector is slightly different from the IDE found in a standard PC. Pin 20 appears to be used in the G3, but isn't on the drive itself. However, on the 80 conductor PC cable, there is nowhere for that pin to go. could I modify the pc cable so it will plug into the board, or could that damage my G3?
Edit: Clarified what I was talking about.
