No benefit, although if you are installing 16MB SIMMs on one bank, the other bank must be populated.Is there any benefit to populating all of the slots? Or just the first 4 should be good enough?
This is what I plan to do.I run 68MB in my SE/30, and I’m happy with it.
BlueSCSIv2 w/ Wifi (for that sweet Daynaport emulation)What other upgrades do you plan to do?
As far as I know, the Daynaport emulation is a beta/experimental thing and doesn't work very well (at least, if you go off all the numerous support threads that exist on this forum as at least one reference point of it not working well).BlueSCSIv2 w/ Wifi (for that sweet Daynaport emulation)
Try oiling the bearing in the stock fan first - Apple did use an appropriate fan spec to ensure the flyback transformer and power supply were cooled sufficiently. It does somewhat depend on how many hours you're going to use the machine for, but just putting a low cfm fan in there may not be the best idea.Changing out the fan for a quieter one.
I've actually been quite impressed with the Daynaport emulation on my tiny scsi/Zulu derivative. It's not the fastest (60 KB/s max) and range is shorter than typical wireless devices, but within those constraints it's been working reliably as I play with it. Any network access is more than none, for sure.As far as I know, the Daynaport emulation is a beta/experimental thing and doesn't work very well (at least, if you go off all the numerous support threads that exist on this forum as at least one reference point of it not working well).
1MB isn’t enough even for system 6 my friend.i think 1mb is good
I have to try that nowOh 1MB is enough for System 6 but you won't be doing much with it. Here's a 512Ke running System 6:
| RAM Slots: | 8, 30-pin SIMM |
| Min - Max RAM: | 1 MB - 32 MB |
| Min RAM Speed: | 120 |
| RAM Sizes: | 256 K, 1, 4 MB |
| Install in Groups of: | 4 |
