Nglevin....
Point well taken re making floppies from USB 1.1 speeds vs USB 2.0 speeds.
RE your post to this enclosure:
I tend to suggest FireWire 400 for OS 8.6/9.x since it comes close to USB 2 transfer speeds and you can find some HD enclosures that support it pretty easily. Here’s one:
https://www.ebay.com/itm/Iomega-3-5-White-Sata-USB-2-0-HDD-Enclosure-iomega-31735000-Hard-Disk/253814875448?epid=1653567965&hash=item3b188ba538:g:dlIAAOSwarpbcxOF
So I run a Firewire 400 cable from the back of the B&W, and plug in this enclosure. If I never install a hard drive in this enclosure will the port on the back work? See photo.
I need to dive into early OSX versions. That you for the additional information.
mraroid
mraroid
