Hi, I have a recapped SE/30 with an ethernetcard installed with driver. Then I am using a Vonets VM300 Wifi-bridge connected to the ethernetconnector from the SE/30, which is configured and connects to my WIFI-router. When I connect the Vonets to the Asante card I get a steady green light on the LED next to the ethernetconnetor on the back of the SE/30. I just want to ask for tips on how to configure the SE/30 and my WIFI-router to make them see each other. I want to use this to FTP files between my OSX10.11 iMac and the SE/30. I will only use this for file transfers, no internet or email. I have manually set the TCP address of the SE/30, so that it is different from my iMAC and router IP addresses, here is the screen on the MacTCP control panel:
For the SE/30 to be recognized I guess I must manually set up the SE/30´s IP address in the router configuration page? (shown in picture). If this is correct, is there a quick way to check if the connection is working and the SE/30 can see the router? Are there further steps I must take to make FTP work on this system?
I am planning to use the FTP program NetPresenz 4.1 for file transfers on the SE/30.
Any help appreciated.
