Help Needed for ROMINATOR ROM MOD for Macintosh SE for PiStorm Booting
AlexCL
Greetings,
I've gotten the PiStorm to boot on my Mac SE with a softROM file of the Mac SE FDHD base ROM.
Floppy and SCSI are not fully functional and since I can make the ROM bigger than stock I am attempting to implement the "ROMINATOR I" driver in the Mac SE ROM to allow me to add a ROM Disk for booting.
From the this post on the creation of the ROMINATOR...
http://synack.net/~bbraun/plusrom/index.html
I have:
1. Disabled the ROM Checksum (I just put in the end routine jump on the first line of the routine).
2. Concatenated the ROM Driver to the end of the ROM (0x040000).
From reading the instructions on how the original ROMINATOR was put together I need to:
1. Find a driver unused by the Mac SE ROM for the resource number.
2. Set the Sound Driver to jump to the ROM Disk driver at 0x040000.
3. Modify the ROM Disk driver to jump back to the Sound driver...or add the sound driver either at the end or in the photo Easter Egg part of the SE ROM.
At that point I can Concatenate a disk image to the modified ROM and attempt booting.
Any help with the above tasks would be appriciated...I don't know 68000 code well enough to put the right addresses in the code.
I have the current modified ROM (SEFDHD.ROM) in the repo below booting in mini-vMac and on my read Mac SE with the PiStorm:
I'm curious about your progress with the PiStorm...
But I'm also curious about the ROM modifications. It would be neat to just have some custom bootable ROMS for the SE .
So I looked at the GitHub. How did you get the PiStorm to boot? Do you have some of the initial configuration? I did not see them on the GitHub
