OK guys,
I've spent some hours trying to ID a couple of Quadra boards I have - searching all over the web. Haven't found affirmative answers yet.
Main source of information is the following (and the link at the bottom of the same page):
http://homepage.mac.com/schrier/wombat.html
The mystery:
Basically the boards are almost identical but the BIG difference is that one has a 64pin "SIMM-slot" to the left of the DRAM slots, named J24, while the other has the pins for the slot, but not the slot itself. (what is this slot for anyhow?)
Another difference: one says "WOMBAT" next to the part number (8xx-xxxx-xx, I forget right now), while the other does not. The one named Wombat is the one with the J24 slot. As an aside, they are both Wombat boards, since they are labeled with a sticker (near the LED D51) with the designation "WBT/33" or something close to that.
Both boards have R152 (on the backside) installed, but not R151. They also have 16.7Mhz crystals, and thus 32Mhz CPU clocks.
Both also have a 5pin header at J25, but no jumper.
They both show up as Getstalt 36, which is Quadra 650, but I've a hunch at least one is an 800.
Any suggestions from the experts would be appreciated!
The mystery:
