I've got a 2GB Jaz drive and a bunch of 1GB cartriges. I've been using this Powerbook 540c I've got it connected to for lots of things, and have installed the Iomega extension and have used a Zip drive without issue. But the Jaz drive doesn't show up at all.
If I use Drive Setup to scan the SCSI bus it shows the SCSI id but says "unsupported device".
The Jaz drive is connected directly to an HDI connector through a cable. It has the compact form of SCSI (the 68 pin one?) and I have a converter cable from that to DB 25 and the HDI connecter has DB 25 at the end. Since I am seeing it in Drive Setup, I don't think the cable is the issue.
I've tried it with and without the termination switch set on the Jaz which doesn't seem to make a difference.
I've tried it with a cartridge in at boot time, and with a cartridge inserted after boot. Nada.
Anyone have any ideas?
