If the batteries leak, then they're either being charged or you're using cheap batteries. Batteries should never leak when they die.I have used those kinds of batteries and holders on old PCs before, they work fine but all eventually leak.
Yes, it'd be more permanent to solder them. Soldering a single wire at a time is pretty easy. It's much easier than soldering components.I wanted to do something like that but don't know how. Would I have to solder the wires to the existing battery socket? If I could attach the wires without soldering, that would be better. It would help because I use rechargeable AA's so I wouldn't have to buy batteries very often.
Wow... If I were to count, I have less than twenty, most doing something useful. I'm still trying to find a useful place to host two m68k Macs - one is a Quadra 610 for which I need a NuBus adapter so I can have two ethernets so it can do NAT...76 I believe is accurate. It's easy to lose track. The link to my machine list in the 68kmla wiki is in my sig.![]()
The machines I have setup, 6 for me and 2 for my wife, are all setup for specific reasons. I'd like to at least setup another 5 once my remodel is done. Most of my collection are "rescues" that were going to be thrown out, or ones that I received as payment for computer work I've done. I've only bought (either new or used) maybe 20 of them.
Thank you. I like to keep old machines running, although I'm not super-sentimental about keeping them completely original. Many of mine have added oscillators, m68040s with permanently attached heat sinks, QuadDoublers, batteries, et cetera. But seventy six... Damn! That'd be around $450 just for the lithium batteries if you put two in each machine!Interesting suggestion about the capacitor and diodes... I'll have to give that some thought.
