PowerBook 170 PRAM battery question.
Hi.
Just popped the PRAM battery out of my PowerBook 170 and was planning on replacing it with a 2032. I have the gear to make one I can solder in, but I was wondering if anyone has ever used a holder instead? it adds a bit of height so I'm not sure, but thought I'd ask here before I have a go and find out the hard way.
Thanks
uhh... i'm pretty sure the stock coin cell is rechargeable...
cr2032s are absolutely not rechargeable. generally attempting to sub a non-rechargeable battery in a charging circuit will cause bad things to happen.
The Panasonic VL-2330 rechargeable coin cell batteries (which I believe is the same as the stock battery) are still available, even on Amazon.
I put one into my PB160 and it works great. Also put them into my 540c and it works well there too.
Oh! Wow! Thanks both I never bothered to check that in the service manual!
I just assumed it wasn’t rechargeable
Dodged that bullet!
I’ll just pick up another one of these then.
