One of my OS 9 machines is a G4 (AGP) with an Giga Designs G4 1,4 GHz upgrade. It worked quite well for about 2 years now, until 10 days ago when it began to hang permanently.
The machine got an ATI 8500, a Stealth port, a SCSI card, 512 RAM and 2 IDE HDs. The used system was an 9.1 installed with the original G4 400/ and than upgraded to 9.2.1 and 9.2.2 manually before installing the G4 1,4GHz.
The symptoms began 10 days ago with several freezes without any systematics. Yesterdays I thought about installing a new 9.2.2 with my original G4 9.2.2 CD (from another modell).
The G4 hangs permanently. During installation of the OS, while booting and even while booting from CD! So I´m afraid it could be a hardware problem. I began with the discs, using Disc warrior - which worked after the 3rd time because of the freezes - who found no big problems. Later I installed a completely new HD - same behavior hangs during install-process etc.
Sometimes the computer now works for 30 minutes, sometimes for 10 seconds, I got no idea at all, ... As the problems occures while booting from 3 different systems/discs and even the CD I don´t belive it´s an software problem. The original hardware-diagnose CD refuses to work with the upgradecard, ...
Now as I´m not familiar with New-World machines, any useful hints? I just can go on and exclude every part (Upgrade, Ram, etc.). Had anyone of you a similar problem after years? Can RAM die from one day to another?
