G3 ZIF Upgrade with overclocked Systembus?
avw
This question might be very specific, but perhaps somebody has tried this before? I own a PM G3/233 DT that I overclocked very sucessfully to 83 MHz systembus speed and 292MHz CPU speed. This machine is a lot faster when overclocked, and totally stable (I would have been the absolute hero in 1999 with this computer ;) ). Especially the systembus seems to make a real difference. Now I got my hand on a Sonnet G3 1 GHz upgradecard. Inside the BW G3s this card is clocking down the systembus from 100MHz to 66.
Now my question is if I can try to use this upgrade with the overclocked systembus inside my G3 DT? Or may I harm the machine? Or should it simply clock down the systembus again? Or may it perhaps work with the 83MHz?
You might wish to check some of the old articles at xlr8yourmac.com on clock chipping the Beige G3, but if I remember correctly, the bus speed on the Beige G3 is controlled by a jumper in a bank of jumpers and the settings on the ZIF have nothing to do with it.   So, if you install the card in a Beige G3, you should get whatever bus speed you have set using the jumpers.
The 1 GHz PPC750 (G3) supports a bus multiplier up to 20:1, so be careful what settings you choose.   With an 83MHz bus speed, you could, in theory, end up with a 1600+ MHz G3 speed.  Probably wouldn't damage anything, but won't do it any good either.
I think that ZIF defaults to 10:1 when first booting though, so you should be okay.
The G3 B&W has the same jumper, but different settings.
I agree with the xlr8 Mac site. Most of this info is there.
