I've got a Newer Tech MAXpowr G3 upgrade card (400/200 DT351) on a PowerTower Pro logic board. When verifying checksums on larger DiskCopy self-mounting images, each time the calculation ends with different (and wrong) checksum values. Swapping RAM or loading the .smi files off the network doesn't fix the issue. Switching to a 180MHz 604e card I have laying around does fix the problem so I'm operating under the assumption that the G3 card is to blame.
Anyone ever experienced something similar with a G3 upgrade card? Am I missing something obvious that might be causing this problem?
The G3 card seems to run fine under normal desktop operations but I'm assuming a problem like this is going to result in creeping data corruption issues eventually. I unfortunately don't have another system around here with the PowerMac PCI daughtercard slot to test with, but I'm not opposed to increasing my collection to help test if needed
