My sister's B&W Powermac went completely bonkers, so I handed over my Ruby iMac.
Originally it ran just fine with 400MHz, 128MB RAM, and OS 9 (Japanese), but since my sister isn't too good at reading Japanese and wanted all of her data from her Powermac, I thought I would take the hard drive from it and pop it in. While I was in there I also swapped out the logic board from a 400MHz to a 600MHz board, and added an additional 128MB of RAM.
After reassembling the computer, I power it on and... No chimes. It pops up with the OS 9 System folder with a question mark, flashes for a bit, then tries booting OS X Tiger. It loads.... To a point. After a minute or so it goes black and does this number:
It'll sit like this for a while then go to this:
I tried getting it to boot my Tiger CDs, but it just continues as if there's no disk in the drive. And I know these disks work since my eMac boots off of them, just like the B&W Powermac did. I can't begin to think about what's wrong :O I know I need to reinstall OS X, but what can I do if it won't boot the CDs? Is there a way to force boot like the earlier Macs?
Also, once when she started it (while I wasn't in the room), she said that it made a really loud beep, then did the same thing it did before.
Is it possible that the fault is on the logic board? I haven't tested it before since the iMac it was in before had a dead power supply... But come to think of it, this iMac never chimed, even with its old board :-/
