So I found a Fujitsu case for the older 230MB MO drive that I thought would be perfect for my 2.3GB drive. That way I'd have an official nice looking Fujitsu case for my Fujtisu MO drive.
*trumpet* Waaaa waaaaa.
As you can see, it doesn't line up. The older 230MB drive has an obnoxiously large bezel. It doesn't really fit in anything except this case. If you put it in a normal SCSI case that doesn't have adjustable screw holes, it'll protrude outside the case. Here's a side-by-side comparison:
So I had to find a way to make the screw holes line up for my new drive. I (thought I had) measured the difference, then I created and printed out a bracket:
I didn't get pictures, but the thicker section is where metal pegs that hold the rubber grommets go. Turned out pretty close:
It's inset a few millimeters, I guess I was off a bit. However, I noticed that's flush with the inside of those decorative grooves. Also, the inset will keep the dust out. So I figure I'd leave it. Looks good, it works, and won't get dusty like my other one.
