FTP Woas
I cant find a good forum to put this in, so ill put it here.
I am trying to transfer files without discs between my main PC running Basilisk II which is a windows 7 x64 machine. so obviously the ethernet driver is fail. NAT works, and so does Fetch 3.0.3 the emu is running OS 8 and I have stuffit delux 5.5.1 installed.
I am attempting to transfer files over to my powermac 5260 which is also running OS8. but it has NO programs installed, NO fetch and NO stuffit. i managed to get fetch with iCab.
And i found stuffit 5.1 on my OS9 CD.
So i am using FTP Fetch 3.0.3 to login to my linux-based server to upload files. it gives me a choice to upload macbinary, or binhex, or etcc. ive tried them all and they come over corrupted. if i upload an hqx or bin, my stuffit will not unstuff, it gives type -39 errors after "Decoding"
So i tried stuffit 5.5.1 to stuff the files i am uploading, and i also encode them with stuffit instead of fetch. and i just use fetch to upload raw.
Same issues.
any ideas? first time ever FTPing between macs.
Well, the program is set to automatic on everything. I have never used Fetch before, so if you have a good way to set it up, let me know.
did some more testing, even tried uploading and downloading from the same machine and same client, still problems.
So i compared the file i uploaded, and re-downloaded side by side, its a couple hundred or so bytes shorter than the original file. wonder why that is? thats seems to be whats breaking it.
Its a bug in fetch 3.0.3 uploading system. BOOO that means i am going to have to figure out how to write a new one. lol.
I setup basilisk to mount my C drive, i went ahead and stuffed + BinHexed my files like i normally do, but instead of using fetch to upload them, i installed filezilla on the host PC. transferred the files out of the emu, and uploading via filezilla.
Then i downloaded them with fetch 3.0.3 and it works perfect. you just cannot upload with fetch 3.0.3, or the files get unexpectedly truncated.
