Looks like it's an Encore ST G4. 1Ghz.The Sonnet G4 designed for Cube will not need an upgraded VRM; in the day Sonnet upgrades weren't bleeding edge and I didn't think much of them, but now they're my choice for upgrade as they are reliable and stable.
It did.I'm not sure exactly what that means but perhaps it originally intended to go with a VRM upgrade.
Fan is already installed, so no problem there.It did.
For 800MHz and 1.2GHz you need SGC-KIT which includes a fan and mounting hardware for the CPU card.
The 1GHz needs SGC-VRM which included everything that came with SGC-KIT plus a new VRM. As said this is due to the 1GHz beeing an overclocked 800MHz 7450 which is getting really hot because it is running a higher core voltage to take it to 1GHz.
You need the fan for any upgrade faster than 800MHz.
A Dual 500 (from a Digital Audio) is possible, with relatively minor mods.
Stick with the 1Ghz, unless you have apps that can take advantage of the dual processor, both the OS and app need to be written to take advantage of the duality... some apps won’t even see that there’s 2.How’s that for OSX performance (generally) vs. a single 1ghz?
OSX definitely knows when it has dual CPUs. Even if a particular app isn't written for it, I've had better overall productivity on duals because I usually have multiple programs going. Here is one of the comparisons I remember seeing:both the OS and app need to be written to take advantage of the duality..
