Compact Mac w/10" Color CRT inside a standard carryall . . .
Trash80toHP_Mini
NIGHT STALKER
68040
.  .  .  retains Peripheral Correctness, even if the neck/board won't fit inside the Compact's bucket. If there's historical precedent and it fits in my carry bag, it's kosher. I cheat very neat. [:P] ]'>
I got tired of sitting on this one, so I thought I'd whack it together and share the concept in case someone else wants to give it a shot. This one's going on the back burner pending other developments.
Neck Board offset PCB will be required to fit everything into the available cubic. As you can see, while the ceramic nipple will fit the rest of the neck board needs to be dropped and offset to fit in the case extension.
This would be the Peripherally Correct part:
The parts for what appears to be this generic HDD enclosure are fairly large, but modeling and printing them ought to be possible. I'll probably wind up going the clear plexi route as has been the plan for the "visible" ZipMacPLUS™ i've been hacking away at yet again.
Started with the spare SE/30 bezel in combination with the visible bucket, but realized that the HUGE CRT would likely block vertical expansion options.
Moving the SE/30 board to the Mac Plus puts the FDD much higher, the fact that the FDD opening has already been modified for a stealthy Zip drive installation makes it all the better!
There should be plenty of room to do a shielded, three level build with proper cooling. Zip drive and HDD will be on a mezzanine level located between the CRT's A/B and the CPU cavern below that you can see in the first couple of pics. Moving the A/B backward into the "shed" provides more clearance between it and the CRT.
Expansion for the SE/30 will be done IIsi style. A IIsi oriented TriSlot version of the ProtoCache1 DevBoard should fit with no problems.
Haven't tested the Monitor with Radius Color Pivot II/IIsi output yet. I'll get an enclosure built with an extension grafted onto the shed roof of the BacPack extension for using the rig as a monitor for the time being. It doesn't claim to be an AutoSync monitor, but the different resolutions at various frequencies the manual says it auto-detects and locks onto give me some hope that  640x480 from the whacky world of early Mac video incompatibilities might just pan out.
If not, NuBus on SE/30 and VGA outputs beckon. ::)
edit: BTW, the depth of the plexi form for the Bacster extension is not to scale. Depth isn't the limiting factor, keeping the neck bits within the Bucket matched angle of its shed roof has always been the goal and I appear to have gotten there at long last! [:D] ]'>
Forgot the pic showing the fitment details re the nipple/ceramic cap juuust fitting:
If the need s be, the diamond blade'll nip/tuck that ceramic cylinder's top/back edge to match the pitch of the roof. [}:)] ]'>
The overhang of the BacPack is the perfect place to hide the analog wheelie thingies (mounted for easy access) via an extension cable.
Wow this is really cool, awesome job. The benefits of a Colour Classic but with true classic mac styling.
How does it look from the front?
Thanks! [:)] ]'>
If I can't get the monitor to sync to an SE/30 VidCard along with my 50MHz PowerCache, I'll just have to go TAKKY with a 6500 board conversion to put 800x600 and 1024x768 on the CRT. The processor would run about 5 times the clock of the PowerCache  .  .  .  with a nice purple heat sink on the G3. PowerCC goodness at 1024x768 fitting right into my standard Macintosh carryall without Espresso defacement of the Compact form factor. I could live with that. [;)] ]'>
The front looks very good so far. I sanded the insides of the opening down and away on the back side so the larger CRT meets the bezel very nicely along the bottom where the mounts pull it tight up behind. The top is only clipped back with studs and nuts so it won't fall backward. I have to work out a method to pull it toward the bezel edge, holding it more securely. Worst case would more sanding on the sides. Don't want to take it too far or the outline of the active area edge of the CRT might peek out underneath.
If the light is right in the morning I'll post some pics. Couldn't really do it with flash.
