Color Classic no power issue debunked!
if that Y2 is rotted off, then your cc is going not not only need it but a lot more, including a re-cap.
the nice thing about that Y2 is, its the same on quite a few other 68k mac boards.
OK .  Thanks.  I have replaced this board with a Color Classic II board.  I thought I would use my original color classic logic board to try to do a re cap my self.  That way, if I screw it up, I will still be running my color classic II board.
But I do not know what that part is, and if I can buy a new on on, say, Mouser or Allied electronics.
Can you tell me what it is and what I should search for?  It is the crystal right?
Thanks
jack
It's definitely a crystal. The only identifying info I can find on mine is: "S3238E", which when I google brings up other threads including one you participated in over on AppleFritter. A thread over here indicates the SE/30 uses the same crystal, and according to schematics I've seen that crystal is 32.768 KHz. This is a very common frequency used for real-time clocks so it's no surprise that it's 32.768 KHz.
This will be a crystal you can find at any supplier. Just search for a through-hole 32.768 KHz crystal. You'll see plenty of results that look just like the original (cylindrical can, radial). The unfortunate thing is that I can't find anything about the original part number, so I don't know the details about the load capacitance of the crystal. Typically you're supposed to match the load capacitance to the circuit. You might just have to guess and hope it works (it will probably be fine).
While attempting dougg3's fix with the wire between the crystal and C56 I managed some spectacular feat of clumsiness and lost C56. I looked everywhere but it's in the land of left socks or some other mysterious locale.
Does anyone know the value for that cap or what I can sub with? I tried 10uf but that didn't seem to work. I'm still getting the static noise when the power switch is flipped but no chime on soft boot.
Here are a couple of photos of the board as it is.
