Hello! I have a Mac SE that runs an desktop BlueSCSI 1.1a from the internal HD connection. I have it wired with the LED and everything. This works fine. I recently assembled a BlueSCSI 1.1a DB25. I can't seem to get this one to work from the external port on the SE at the same time as the internal BlueSCSI. I can have one or the other. Both work until I try to run them together on the SE. When I try to run them both, I get the floppy disk with a question mark. Any idea what's going on? I tried changing the boot order on the HD images and that didn't help. If I disconnect the internal bluescsi, it works. I also got the DB25 to work on another computer that is just boots from a standard HD. Any ideas? I suspect that there is some sort of SCSI chain problem that I'm not understanding...
