I'm quite sure Apple HD SC will not work.
I suggest you just try to mount the image I sent with Lido or similar.
The BlueSCSI doesn't work with partitions. You should have a single partition for the whole card and put your HDA files there. Each file will be recognised as a hard disk (or CD).and...if I try to create 2 partitions: one exfat 20Mb with a bank .hda image and the second in another format that is not recognised by The plus ( HFS+ for example) , do u think that Apple SC HD Setup will try to initialise only the 20Mb partition??
Hy! Ok, not partitions! No, I haven’t had time to try with LIDo, I will try tomorrow!The BlueSCSI doesn't work with partitions. You should have a single partition for the whole card and put your HDA files there. Each file will be recognised as a hard disk (or CD).
And as I said, Apple SC HD should not be used.
What happens when you list the SCSI drives with Lido?
enough space in rom disk... I never saw this before... Could you post a photo of the error? I'm very curious about it!It works!!!!!!!!!!!!!! but there's only one problem. when the plus starts, a message that there's not enough space on rom disk appears. I can work, and made some operations. why this message appears?
