Bizarre SE/30 Problem
CC_333
68040
Hi,
I am working on another SE/30 logic board, and have done a full recap. It works perfectly (good, loud bong and all), but I can't move the cursor. Now, what makes this odd is that it will still register clicks (the Apple menu will open when I click) and the keyboard works fine, but I can't move the cursor!
I've tried two mice, and they both behave the same way.
Why?
c
i'v had L1 go out before...
other wise its a trace issue.
i would check
C13
Q3
UL11
we know F1 is good because the kbd works…  I'v had blown out F1 before as well.
OK, C13 is good I think, but Q3 is suspect (it took some relatively heavy corrosion).
I'll take a look at UL11 as well.
c
