Hi there,
I might be able to get my hands on a boxed Quadra 950. I like the fact that it's got a full 040 (It would be a first for me. My fastest 'classic' Mac is a 50MHz SE/30 but an 030 cannot run everything). I also love the fact that you need a key to start it up as well as the form factor itself (I think it will look good alongside the Mac Pro and my broken G5)
My plans are to upgrade the RAM and the VRAM to the maximum amount, and install OS8.1. Apparently the graphics card on this thing surpasses anything available on the market, so I probably won't need one of those except if I want to run a dual monitor setup later in the future...
I would like to get an OrangePC card for any DOS stuff I might want to try. I don't want to get an IBM compatible as it's not my thing.
I don't want to get a PPC card either as I've already got a G3 and a turbocharged G4 that should be more than enough for early PPC stuff. The Quad G5 (once fixed) should take care of anything post 2000 with ease.
That leaves me with 4 unoccupied slots. So my question is, what would you put in there?
SCSI2 + SSD? Is there any real advantage to get a Rocket if you don't do virtualization?
Thanks!
Thanks!
