asking for opinion: WGS 8150 vs. Radius 81/110
I have both of these, but only enough parts to max out one of them. The positives I see:
Radius has internal fast SCSI and integrated video.
WGS 8150 has a tape drive, is a bit smaller, and it's a WGS.
Whichever one I end up using I will also put in a Sonnet G3 266, an ATTO SE IV D SCSI card and a ProTools Audio Card; even though the cable is the same I think I can only plug in my 442, and not my 888 interface.
I could go either way, are there any issues or problems I may have to deal with either???
The Radius is the greater rarity. WGServers are no different than ordinary Macs of the day, though both (?) machines likely have an extra large L2 cache. If it's 1MB, the chip alone is probably worth more than the computer, so don't throw it away when you stick in the G3.
I like the 81/110 Radius, and I own one. Still the tape drive in the WGS 8150 is nice, but I have externals so backup is not a problem.
Radius Rocks! I've been using their products since '87 and the one I love most is my 81/110 with the Radius VideoVision Studio Setup.
I liked its design so much that I snagged a NIB 81/110 faceplate on eBay and I'm building my PC based ubuntuGIMPbox to make use of it. The 81/100's wider faceplate allows me to do a drop side, clear plexi deal. The sheet metal case on a Radius Clone is head and shoulders above the Apple Plastic Wonders of that era, in terms of packaging.
Design of the two cases is a matter of taste . . . but who backs up to tape anymore anyhow? :?:
I have started the upgrade, almost finished but ran into a snag. I can not get it to recognize the G3 card and when installed it will only startup with extensions off. The card is a Sonnet G3 266 1 Meg cache. I followed the directions, installed the crescendo 1.44 software, removed cache, processor is seated properly in slot. I ran Norton SystemWorks from the CD and there were no problems. The OS is 9.04 with nothing else installed. The one thing I have not tried is installing a PDS terminator in the G3 card. The directions say nothing about this, but I would assume it still must be terminated? Anyone have any tips?
If there's provision for one, it sounds like a very good idea to try one, I doubt it could hurt, if there's a slot to put it, or female sockets for SIP resistor packs, I'd do it in a heartbeat. You've got that funky two slot setup with the ribbon cable, IIRC?
If so, terminating the cable interface would likely be standard procedure. Post some piccies of the upgrade process, please. This sounds like something I'd really like to do with my Radius81/110-VidCapPlayToy/MacFurniture™_Support! [;)] ]'>
Do you have a JackHammer card installed? The Sonnet upgrade was incompatible with the JackHammer when it was first released. I think Sonnet solved that later.
Another possibility is that the G3 card has a defective backside Cache. I saw this on a NewerTech card once. It worked fine until an extension enabled the backside cache and then it would crash the computer. Turned out the cache was bad.
If you have the SA4 Protools Audio Card installed then yes, it will only connect to the 442 interface and not the 888. If you have the even older SoundTools audio card, then the only thing you can connect to it is the PRO analog, DAT, and standard Analog SoundTools interfaces. I've never tried and honestly since my 888's were and still are a bit pricey I'm not going to try that one. The 888's and 882's will hook up to a standard Digidesign SA8 (Elvis) Disk IO card, or the Bridge Card.
If you need the older Protools software that supports what you have, let me know. I have a cd made up for this type adventure.
The SCSI card that I will eventually use is the ATTO SE IVD, but it si currently not installed. I'm pretty sure that both ProTools cards I have are the SA4 kind, but again, not installed. The RAM is maxed, and it worked fine in the WGS 8150 as well as in the Radius before I tried the G3 card. It also has a virtually brand new PRAM battery. When I start with extensions off or boot from Norton disk it says the processor is the 601 110 MHz, not the G3. I might try wiping the hard drive and doing a re-install of OS 9
IIRC, neither the Sonnet, nor the NewerTech upgrades were compatible with the ATTO SCSI card. I may be misremembering though. The forums where I discussed this back when are either gone or hard to get to. I think we talked about this on the XLR8yourmac.com forums and also at PowerWatch.com (power computing user community).
Is OS 9 supported? I honestly don't know. I ran 7.6.1 with my G3 upgraded 8100-equivalent (PCC Power 120).
OS 9.1 is supported on x100 series Macs so long as you use an original Mac OS 9.1 install CD. You cannot use a Mac OS 9.0 or 9.04 CD + the downloadable 9.1 updater.
If you don't have an original OS 9.1 install CD, get your hands on another PowerPC Mac with SCSI. Remove the hard drive from the PowerMac, and connect it to the other Mac, either internally or in an external enclosure, and run the 9.1 updater on that. This really does work - many years ago when my 8100 worked, I got my 8100 updated to 9.1 by putting its drive in an external enclosure and running the 9.1 updater on my PB1400.
I'm guessing my G3 issue was a bad cache, luckily I bought 2 G3 266's in the same auction and the second card works. Unfortunately I do have the OS 9.04 upgrade issue now. I do have a flaky 8600 that I might try the upgrade tricck, but all my other machines are G4, whether stock or upgraded. I'm hoping the ATTO card will not be an issue. I also just won an auction for a nubus SampleCell card; so I'm hoping to max the thing out with the ATTO card, ProTools SA4, and SampleCell. The ATTO will allow me to install 1 or 2 extra hi-speed 18 Gig drives. Slowly but surely getting there... Woo-Hooo!
I think the WGS may have started with 100, but the one I have is the "speed bump" 110. There is a "technically" faster point with the Radius; the internal SCSI buss is faster than on any of the Macs of the time. This is another reason why I'm going with the Radius, I'll use the OS drive on the stock internal buss. I know it will be slower, but make troubleshooting easier.
