Yes I use blueSCSI. Would be nice if you can try this out.... I am currently at the end of my options.
I also tried System6 but OT is only for System7 and MacTCP has the exact the same issue as OT when I try to set to ethertalk3.
I think it's a bug with Apple-Talk.
On the switch the light is green either for IIcx or 6100.
Seems to me that the Card itself is correctly installed. Switching the Apple-Talk from "printer" to "Ethernet Slot3" does not work on System7.
I think my switch is up to Gigabit, but I also use 10Mbit card on another PC and it's working fine, so I don't suggest the switch being the problem.
I took out the OrangePC and changed the Slot for the Asante, I also put a 10/100 switch between and the error simply stays exactly the same. So next card for testing fallaron Nubus.
This is my working disk image. AppleTalk works; TCP/IP probably also (I tested it with iCab, but System 7.1 is probably too old for it since it crashes). You can only ping it once MacTCP is loaded; this is not normally done on startup!
Perhaps it's an issue with the IIcx not being 32Bit clean and NODE32 is not installed?
Regardless what the issue is, the Farallon-Card does work perfect on System6.
System7 Installation faild because of a "Network" File that is not visible but has to be overwritten and the Installer does not do that.
I will make a clean Install of SYS 6+7 the next days. Thx!
