I'm still trying.. No working IICX yet and i bought a VGA to DB15 adapter and tried hooking a powerbook G3 to it but no luck.@Sideburn did you ever hook up a working Mac to the CRT?
Well I’m back at it with a repaired PowerBook 180 and video cable so I can test.
The bad news. No picture.
The good news it’s filling the screen with white so it’s doing something.
And it’s showing up on the Mac.
Video and photos attached:
Good point I see some color on the edges of the screen. I’ll try mirroring. And moving windows around.Ah, that is disappointing.
Sorry if it’s an obvious question but is it definitely showing all white, as opposed to a grey pattern? I would try setting a more ‘busy’ desktop pattern than your solid grey one as the PowerBook 180 does not typically show very much else on a secondary screen unless you start dragging windows and icons across.
Another thing to check is the short PowerBook video adapter cable which is not always reliable in terms of making a good connection into the back of the computer.
The retrace lines and the washed out image are the same issue and I would start by adjusting the ‘cutoff’ pot at the back of the display. It’s located above the other pots that you can access at the rear, but you have to have the casing off to get to it.
Set the contrast knob to maximum and set the brightness knob to the middle setting. Then, with the monitor on (but being careful not to accidentally touch any high voltage areas) turn down the cutoff until the black areas of the image are completely black. It may be easier to do this in a darkened room. You will find the retrace lines are gone at this point, too.
While you’re doing this I’d reduce the horizontal and vertical adjustments as the picture is too big. It shouldn’t go right up to the edges of the visible area, instead there should be a black border.
The convergence is a different issue and I suspect it’s probably caused by bad capacitors that are no longer operating in spec. It’s not an easy adjustment to do and personally I would recap the monitor before fiddling.
@jmacz helpfully provided us with their cap list here: https://68kmla.org/bb/index.php?thr...on-monitor-weird-distortion.43266/post-496854I want to re-cap it as well. Unfortunately there’s no cap kits that I can find on console5 or elsewhere so I’ll have to build my own BOM and order them.
You could always try to play with the convergence but what I suspect is that once you recap it, it will need adjusting again. Maybe you could mark/record how it is adjusted now so you can go back to the original settings if needed.
Btw, even on my properly set up display, my brightness knob has a very limited range as well. It’s not very useful.
Hmm, I think you’d need to remove them to get the correct readings. It’s a lot of caps indeed.Ahh ok good to know. Maybe I can ESR check the caps in circuit?
