Apple IIc ADT Pro file trasfering Problem
Hi all,
my apple IIc is suffering a strange problem iw reads and writes floppy without any problem but sometimes when using ADT Pro at some point the trasfering is interrupted by itself. I've checked everything, my serial adapter, my cables, my drivers, ecc ecc, on my second apple IIc everything works just fine. Initially i've thinked about floppy images, but i had this problem even if i try to transfer the adtpro image itself. Did some of you have any idea about what kind of problem my system is suffering ?
Thanks a lot to everyone will help me with that
Did you make the cable? I would first start to make sure you don't have any cold solder joints, or bad solder joints. I just recently had this issue, where a wire broke off on the din side of my cable.
