Hi all,
Just finished recapping an Apple II PSU, model A2M030, and figured I’d share the capacitor list in case it helps someone else restoring one of these.
I tried to keep replacements close in size/lead spacing while using decent modern Panasonic series parts (mostly FC + EE series).
The original primary-side caps were 250V parts, but I went with 450V replacements since they fit and give a bit more margin.
Mouser project:
https://nl.mouser.com/api/CrossDoma...ync=False&setPrefSub=False&clearPrefSub=False
Hopefully useful for future restorations.
Cheers!
| Ref | Original Value | Diameter | Height | Lead Spacing | Replacement Part |
| C5 | 47uF / 250V | 18mm | 38mm | 7.5mm | Panasonic EEU-EE2W470S (450V) |
| C3 | 47uF / 250V | 18mm | 38mm | 7.5mm | Panasonic EEU-EE2W470S (450V) |
| C2 | 47uF / 250V | 18mm | 38mm | 7.5mm | Panasonic EEU-EE2W470S (450V) |
| C4 | 47uF / 250V | 18mm | 38mm | 7.5mm | Panasonic EEU-EE2W470S (450V) |
| C7 | 680uF / 16V | 13mm | 43mm | 5mm | Panasonic EEU-FC1V681 |
| C15 | 1000uF / 10V | 13mm | 43mm | 5mm | Panasonic EEU-FC1V102 |
| C16 | 220uF / 10V | 10mm | 21mm | 5mm | Panasonic EEU-FC1H221S |
| C18 | 330uF / 16V | 13mm | 25mm | 5mm | Panasonic EEU-FC1H331 |
| C9 | 1000uF / 10V | 13mm | 43mm | 5mm | Panasonic EEU-FC1V102 |
| C10 | 1000uF / 10V | 13mm | 43mm | 5mm | Panasonic EEU-FC1V102 |
| C13 | 1000uF / 10V | 13mm | 43mm | 5mm | Panasonic EEU-FC1V102 |
| C12 | 220uF / 10V | 10mm | 21mm | 5mm | Panasonic EEU-FC1H221S |
| C11 | 330uF / 16V | 13mm | 25mm | 5mm | Panasonic EEU-FC1H331 |
Mouser project:
Cheers!
