If so, I wonder if you might be willing to do me a small favor... I'm seeking a trace of the AppleTalk network activity between Mac and ImageWriter when a print job is being sent. There are a few different ways to collect such a trace:
If you have an AirTalk and Mini vMac v37 with LToUDP, you could connect the ImageWriter to the AirTalk's LocalTalk network and print to it from Mini vMac, collecting the trace using Wireshark.
If you have a TashTalk Hat, you could connect the ImageWriter to the TashTalk's LocalTalk network, run tashtalkd, and print to it from either Mini vMac (collecting the trace using Wireshark on the machine running Mini vMac) or a physical Mac on the LocalTalk network (collecting the trace using tcpdump on the RPi with the hat). Alternatively, you could run TashRouter and print to the ImageWriter using a Mac on the EtherTalk network, collecting the trace in the form of TashRouter's log output.
All possibilities (that I'm aware of) require having an AirTalk or a TashTalk in some form, and if you're willing but the above approaches don't work for you, I'm more than happy to work with you to find one that does.
The printer doesn't have to work perfectly, if it thinks it's printing properly, that should be good enough for my purposes.
Thanks in advance! =)
