Best I can imagine you'll find is a PCI Nvidia 5200FX card. There are BIOS flashes out there for PC ones that supposedly will do CI even on a B&W G3.finding a video card that supports QE/CI for it.
I'd be interested in seeing numbers showing that an xserve at a particular speed was actually any faster than a Power Mac. The Power Macintoshes generally shipped at higher frequencies (dual 2.7GHz, dual/quad 2.5GHz) and I haven't heard reports of those systems throttling due to heat concerns, which would be interesting to see/hear because Apple made having those cooling channels/chambers a pretty big priority with the Power Macintosh G5, so unless it is actually better for the air to scream by in a small space than for it to scream by in a large space, I would think that the PMac would "win" or that they'd be equals.The Xserve G5 was probably the best incarnation of the G5 ever made; its cooling system was if anything overbuilt and it let the CPUs fly in a way the desktop versions never did.
LOL! I haven't checked (fiduciary discretion re the 68k collection's needs) but if the early G4 ran a version of X that supported Faux9 and had center mounts for my TelCo rack I'd be all over one. I miss using the QS'02 under the desk to keep my own feets warm in the winter. I still run slide shows on it to keep it awake and running as a white noise generator/space heater unit overnight in the bedroom. Working on setting the MDD'03 Native9 special edition as an eventual replacement for more efficient production of noise and heat.I have an Xserve G5 stuffed back in a closet, although I don't run it all that often.
It's a LOUD beast, though, and also throws out a lot of heat. The closet it's in has no ductwork running to it and is on an outside wall(it's a big walk-in that's in the upstairs hallway). In the winter, I'd guess it hovers in the lower 60º range if not the upper 50ºs with the house in the mid to high 60s. If I turn on the Xserve and have it actually doing something, I've actually opened the closet door to help heat the rest of the upstairs.
The X-serves are designed for 19" Telco racks, although they are quite long. I think the G5 is about 3 feet. Mine came with the unused mounting kit with hardware for both 2 post and 4 post racks.LOL! I haven't checked (fiduciary discretion re the 68k collection's needs) but if the early G4 ran a version of X that supported Faux9 and had center mounts for my TelCo rack I'd be all over one. I miss using the QS'02 under the desk to keep my own feets warm in the winter. I still run slide shows on it to keep it awake and running as a white noise generator/space heater unit overnight in the bedroom. Working on setting the MDD'03 Native9 special edition as an eventual replacement for more efficient production of noise and heat.
An X-Serve in that role would be beyond cool! :lol:
I will photograph it, but my Xserve G5 shipped with Tiger. The box lists it as such, and it includes the Tiger media in the box(as I mentioned above a full-size retail box version of PPC Tiger).The first models of XServe shipped with OS X Server 10.2.whatever, so you could run retail Panther or Panther Server on them.
EveryMac will list every model of XServe and what the min and max OS for them are. In general, the minimum OS will only be achieved by using the original restore media.
Just for completion of the thought, the last generation of G5 XServe shipped with 10.3 Server and can run up to 10.5.
So, you should be able to run any PowerPC XServe with 10.4/Tiger and any attendant software. This should include Classic Mode.
Apple used to use the term "drop-in upgrade" for machines that originally shipped with one version of Mac OS X, to which they dropped in an upgrade disc to advance the system to the next major version without having to update the retail package of a machine.I will photograph it, but my Xserve G5 shipped with Tiger. The box lists it as such, and it includes the Tiger media in the box(as I mentioned above a full-size retail box version of PPC Tiger).
