ADTPro help
If you use a Super Serial Card, the easiest connection is to move the block on the card to the "Terminal" position and use a straight-through serial cable. I routinely use 19.2 but remember pulling it back to 9600 sometimes. For boot strapping, you may even want to try setting it lower - 1200 or so.
EDIT: the ADTPro page actually suggests setting the card to 300 baud for bootstrapping:
http://adtpro.sourceforge.net/connectionsserial.html
I was trying first to the get the //c working with ADTPro. I think it was set to 9600, i'll go lower and see if that helps.
If no dice with that, i'll try with the ][e next. Only cable available for that i have currently is DB25M-DB25M -cable.
Might get one DB9F-DB25M later on from a friend.
For some reason i have no luck even with Apple ][e with Super Serial Card II setup as terminal and using straight-through serial -cable.
Luckily i have three cards so i can test an another.
