Thanks to Defor, i now have a color active-matrix screen for my PowerBook 520 (now upgraded)
I have upgraded from the following:
PowerBook 520 Gray-Scale
25Mhz LC040
4MB RAM
250MB HDD
Dead battery
to:
PowerBook 540c Active-matrix Color Screen (Thanks Defor!)
4MB + 16MB = 20MB Total RAM
33Mhz 68LC040
250MB HDD
External Zip Drive
External 24x CD-ROM as well as an external 8x2x12 CD-RW
AAUI->10BaseT Ethernet
And thanks to Brooklyn, i picked up:
PowerBook G4 400Mhz
256MB SoDIMM, No idea on HDD, VGA, No Battery, no screen (broken screen and hinges), No keyboard Airport? (not sure) Might have superdrive. I haven't powered it up
PowerBook G4 1Ghz
1GB PC-133 SoDIMMs (512MBx2 PC-133)
No idea on the HDD, DVI (Just picked up a DVI->VGA adapter), SuperDrive, 802.11b/g Airport, No screen, Battery
Gonna try setting up the 1GHz PowerBook G4 later. I picked up a DVI->VGA adapter out at best buy (tried nebraska furniture mart and DIT, but NFM didn't have the adapter, and DIT wasn't open
Anyways, gonna install 10.5 on the 1Ghz, and see what I can do. Does anyone know if the G4 1Ghz has the antenna in the screen or the base? I might have to pickup an external Wireless adapter (PC-Card) or just use ethernet. I also have a Lucent WaveLan but it doesn't support WPA with the driver I have.
Good scores, eh?
25Mhz LC040
4MB RAM
250MB HDD
Dead battery
to:
33Mhz 68LC040
250MB HDD
External Zip Drive
PowerBook G4 400Mhz
PowerBook G4 1Ghz
Good scores, eh?
