6360 overclock/upgrade?
It's easy enough to create them from parts. Except for the PCI opening.
I used to have a Performa 6200 and 6320 and they did both have a PCI opening, you’re thinking of the Performa/LC 630. What you’d struggle to obtain is the single slot PCI right angle adapter.
The slot on the 6200 and 6320 are the same as on the 630. It's slightly different in size and location if you compare.
