3D-Printed Objects
I am thinking the same thing. The only two unknowns would be the height and width of the user-facing end of the buttons. It looks like the height might be the same as the stem part, but I couldn't find any really high quality pictures to tell. The width is definitely something we'll want to measure too. I would think the depth would be the same as the Q700 buttons, since the logic board dimensions and mounting relative to the case are (as far as i know..?) exactly the same between the Q700 and the IIci. I can bang out something quick and dirty if you want, but I would much prefer to get at least those two measurements before having anyone potentially waste time printing one.
@Swolfington
Finally had a chance to take some measurements (I can't find my metric slide rule so I had to go with 1/16s)
Looks like each rectangular button is 13/16" (.8125" or 20.6 mm)
There is a gap of 2/16" (0.125" or 3.2 mm)
So, unless I have fat fingers, that means an outer width (end to end) of 1.75 in (44.45 mm). Eyeballing your drawings, we're in the ballpark.
Hi everyone, I was thinking about my ibook g3 clamshell and I cant stand the missing logo, both parts of it are missing. How would a 3D printed one look? Even if its orange and not translucent, it might still look ok. I believe translucent orange filament does exist though.
Once we’re 100% on the model we can order a run on a SLA printer so it won’t have any lines and then Home Depot sells a near perfect color matching spray paint! If somebody knows how to cast plastic that would be an option also.
Can you post what that paint matches that color? I've been contemplating painting some of my parts, but I haven't been able to find a positive lead on paint color/brand/whatever.
With all due respect to @360alaska, I appreciate the work done on this (that seems to mirror the work that was documented here) - truly, I do - but so we’re on the same page, the bezel I’ve been asking for (which some folks actually have and have been willing to part with temporarily) is the caddy-load bezel that really only has the caddy-length slot and a round eject button. The one you’ve made is the style I currently have that is more of the universal variety; example, I’m using it with a caddy-load 300i.
I’m just glad I didn’t get ragged on for bumping an old thread :)
Nope, I did not use that as a starting point. I did see though and I tried and it was WAY off. I got a syquest bezel off of eBay and mike’d that. It figures that I work hard, make muiltiple prototypes to adjust the length of the clips only to be accused of copying someone else’s untested/defective design.
Yeah, I mean if someone wants I can share it in tinkercad, which is what I use, and then they can edit it and turn it into a caddy bezel. It’s not very hard but for me my only two computers with caddy cds are 550 and 660av.
No, I wasn't implying anything like that - other than if you knew it was there, it could've saved you a bit of work. Turns out you did know it was there and used that as a starting point. The one I uploaded and printed from Shapeways has a slight gap on the right side but I think I used too thin a material (flimsy).
But it (measuring, modeling, and creating the STL yourself) is a good skill set to have anyway, as you noted - especially with supply drying up quickly on old parts like this.
