I'm attempting to replace the original HD with a SD adapter but I'm being thwarted by the clutch covers. The previous owner used some glue to keep the front and back display panels together sometime back in 1999. It no longer holds but it appears that they used quite a bit and the clutch covers will not budge.
Its entirely possible that the glue isn't causing this issue. I'm following the Service Source guide. Only one cover will move slightly but it won't come out. The other will not budge.
Is it really necessary to remove the clutch covers to pull the top case off? Considering the plastics, I don't want to explore that angle without some advice.
