128k mouse issues after RAM replacement
Hi. I replaced 5 RAM chips on my original 128k motherboard. I successfully desoldered the faulty chips, soldered in new ones, and no more sad Mac! It now boots from a floppy and gets to the desktop. However, moving the mouse does NOT move the cursor on the screen. I tried 2 different mice, both of which work fine on my Mac Plus. The mouse button DOES work- I can click and see the Apple menu (because the cursor starts there), but can’t get the cursor to move. I don’t even know where to begin to look to try to repair this.
Anybody have any ideas? Again- it’s not the mouse, but something in the computer.
Thanks!
SOLVED! Embarrassing, but this was just a software issue. I was using System software 4, and 128k Macs can only handle up to System software 3.2. My dumb mistake. Works great now.
Better yet, upgrade to Plus ROMS, and then you'll have native support for HFS and System 6 (except for the drive, you'd then have essentially a 512ke).
c
