Hello,
I have 2 LISA power supplies here.
One thing I can say, for both power supplies
They get very hot.
You can even see black marks on the bottom of the PCB's,
and the ½ - 1 watt resistors on the 1.2 amp version are Crunchy/Crackly looking.
All though, the crackly resistors seem to VOM fine, not to say they do not change once the PSU kicks on.
My god would it have killed them to throw a fan in there?
Anyways,
Here are my symptoms:
1.2a Will Run for a while , and then shut off, Assuming from a heat induced issue.
- was going to just change the caps, but i want to make sure there is not any other common issue
I can take care of while its open.
1.8a Has a dead short some where, was working, and that all of the sudden it stopped working. The 3amp 250v fuse was nuked,
replace the fuse, plug it in and it nukes again
I can include pictures as well - thank you for sharing any experienced thoughts you may have.
They get very hot.
Anyways,
