1/2 AA battery Replacement! MoewToast Rev. 2
yeah, i tried but these are just a little too high and with the holder soldered on, it wont sit straight. will post pics when i can
It fits, but it’s very loose even with the holder - I had to use some hot glue. The meowtoast concept is really nice, but it could use some tweaking so that its fits in more snugly.
I wonder if there are some variations in the battery holder, mine's pretty secure with the clip in place. 🤷‍♂️
People are mixing between the meowtoast and siliconinsider's battery holder. The lay flat thing seems to be for siliconinsider's.
these are the battery adapters i bought
this is what it looks like when i try standing it up, it doesn't sit right. the battery holder gets in the way
the only way this one works is by sitting flat
View attachment 57401View attachment 57402
View attachment 57403View attachment 57404View attachment 57405
View attachment 57406View attachment 57407
You have Silicon Insider product vs MeowToast so laying flat is correct for the Silicon Insider holders. I have both and they are different.
Is Silicon Insider's variant suitable for the Mac II/IIx ? Given that the two battery holders are clamped side by side...
I suspect not. On the II and IIx, I'd be more tempted to mount two AAA battery holders to the case and run some lithium AAA batteries.
