Why is this SE so unhappy?
Hoping to get some help. Local guy is selling this Macintosh SE and I am interested but don't know if I am equipped to get it up and running. What might be wrong with it? Thanks for any help. I search on the interwebs and couldn't find anything relating to this particular error code.
So if this is the case and the ROM needs to be updated. Would you start the SE from floppy and then put new ROM on the HD? I'm just trying to understand if this is a simple procedure since I am such a newbie on this stuff.
It means that either the ROM chips on the logic board or some of the circuitry around them are probably stuffed. You should ask for pictures of the logic board to see whether there's any obvious damage :)
dochilli
The ROMs should be taken out and checked for corrosion. Perhaps a cleaning may help.
You can burn new ROMs with an adapter an 27C010 Eeproms.
Thanks. I might look into that. Sounds promising. I'll have to ask for a picture of the board if he will send one.
sstaylor
To be fair, many people don't have the long torx-15 required to open an SE.
Could be a dodgy seller, or just one who has an old computer they're not terribly interested in.
Very true - I should have said "can't or won't" - but if, like the OP, one isn't used to repairing machines, buying a broken one without seeing what's inside it is probably still a bad idea. But I shouldn't have imputed dodginess to the seller when it may be impractical for them to get inside, you're right.
dochilli
But a SE logic board is often in good condition. I did not see a SE with an exploded battery (like a lot of SE/30s).
joshc
I don't agree. SEs are just as well known to be battery bombed as other models; they often used Maxell batteries and even Vartas can leak. A few bombed SEs have passed through my hands, and I haven't owned many of them.
