Which new Mac is the right one for me?
tecneeq
I have no experience with newer Macs whatsoever. I have a Rev A iMac, but believe it's not enough to play modern, games that where available for the Mac OS 9. So here is my wishlist:
  • should be as silent as possible
  • should be able to play all games that came out, even later ones, within reason though, i don't need the highest settings
  • should be available at ebay for a tiny amount of money
  • I don't mind the size, but i have a 19 inch LCD, so no builtin display.
  • not a monster when it comes to energy
  • TP fast ethernet is a must, so are USB2 connectors
Any models in particular i should consider?
Cory5412
Daring Pioneer of the Future
Staff member
Macs tend to "hold their value really well" -- so to be honest, unless you are specifically yearning for an early 2000s dead-end UNIX workstation that uses a lot of electricity and is extremely good at very specific tasks nobody wants to do anymore (aka the PowerMac G5) then my recommendation is honestly to take a very good and serious look at a brand new Mac Mini: http://www.apple.com/mac-mini/
I've got the model one generation behind with a Sandy Bridge processor, it plays many modern games on reasonable settings, and in the year or so I've had it, it has a) never been turned off longer than it takes to install more ram B) never made audible noise, save for when I'm really pushing it by playing a game or running some folding.
If you're looking for Mac OS 9 gaming (I wasn't completely sure based on your wording) I would get a fast, single-processor PowerMac G4 and put a GeFORCE 4 or 4600 TI in it.
Most (all) games on Mac OS 9 will not take advantage of dual processors, (or even that much ram) and to be honest, if you have the physical space available and want to run both Mac OS X and Mac OS 9, I would do it on two physical computers, if for no other reaosn than to make management of the operating system and disks easier. As an incidental benefit, you wouldn't need to turn one off in order to use the other.
On the OS 9 front, something like this would be perfect, if you could verify that it does not have a Firewire 800 port. (Do not buy an FW800 G4 with intent to convert it, you end up replacing most of the machine and creating more work for yourself in the process.)
Do not bother with the mini or any of the PowerBooks on the OS 9 front, The TiBook@1000 was good in 2003, and stopped being good mid-way through 2005 (and that's being kind to it) and the G4 mini shipped with an extremely similar graphics card. The very fastest eMac fared a bit better with a 128MB Radeon 9600, but it did not run Mac OS 9.
In general though, unless you really do specifically need Mac OS 9, then the mac mini meets your requirements almost exactly, and maybe some 2009 ones with the Penryn Core2 processors and the GeFORCE 9400M IGP are available cheap. (And also $600usd for the current mini is to be honest a fairly good deal if you consider that you're getting Mac OS X, almost enough ram for Mac OS X, and the whole package fits in some cargo pant pockets and uses something like 20 watts at full tilt.)
Cory5412
Staff member
In before "the mini is so expensive compared to equivalent PCs..." (it happens from time to time.)
Here is the only equivalent PC I've been able to find: http://www.lenovo.com/products/us/desktop/thinkcentre/tiny-form-factor/
Everything else is far larger and uses far more electricity. (In fact, even this particular machine needs an outboard power supply.)
There's this: http://www.dell.com/us/soho/p/optiplex-7010/pd -- but it's far larger and uses a lot more electricity than either the Lenovo Tiny or the Mac mini. (Although it seems to be using all desktop parts)
HP has one too, but it's not that great either: http://shopping1.hp.com/is-bin/INTERSHOP.enfinity/WFS/WW-USSMBPublicStore-Site/en_US/-/USD/ViewStandardCatalog-Browse?CatalogCategoryID=TDAQ7hab63cAAAE7IeweMhoS -- this one is using laptop parts again, but at a base cost higher than the mini.
(I mean they're all reasonably nice computers, but you spend a lot of money to get something with the computing power the mini has, and you're not getting quite as nice an overall package anyway.)
tecneeq
I plan to use it for OS 9 gaming only. And i plan to get at least two, maybe even three. They would be put into storage when tricked out, to ripen for a decade or two.
The MDD G4 seems to be the droid i am looking for.
Would you say it's a particularly loud computer under load? I don't mind a bit of noise, but not like a vacuum. How is it's power consumption while idle?
mac2geezer
The only MDD I ever had (the 1.42GHz dual processor model) was pretty loud, louder in fact than either of the G5 towers here. I never measured the power consumption.
waynestewart
The MDDs are all pretty loud. The Quicksilver is a lot quieter. I'd think that the 933mhz or dual 1ghz would be fast enough for any OS 9 game. It also shouldn't be too costly to pick up an accelerator for the quicksilver
antony701
If the silence is important. I would avoid MDDs G4s.
The FW800 MDD G4 I have (1.42 GHz) is damn loud. Further, the power supply of it may not last for long.
I know you said you already own a LCD display, however, an iMac G4 (up to 800MHz) might be your better choice for the noise and energy aspect.
Otherwise, recent Intel based Mac (e.g. Mac mini) is pretty fast, quiet and low energy consumption. They can run OS 9.0.4 with SheepShaver at pretty fast speed.
ianj
I used an MDD G4 as my primary, and sometimes only, computer for 7-8 years. It is definitely loud, but I got used to it. Mine is one of the OS 9-bootable ones Apple released together with the first G5 in summer 2003, so it's a bit of an oddball... it boots OS 9 and has a 167MHz system bus, but has no FW800 and a dual 1.42GHz CPU implanted from a January 2003 FW800 model (I got it new as a single 1.25 and kept it up with modernity the best I could). It got me through high school and college, and it still retains a place of honor under my desk even though I don't really use it anymore.
For OS 9 gaming, though, I'd probably go for one of the earlier G4s. By the time you get to the MDDs, everything was really designed for OS X, so if you want OS 9 gaming, any graphite G4 with a good (for the time) video card and a fast single CPU should do. Are the games you plan to play Mac OS-specific, though? All of my Mac OS 9 games are ports of PC games, and if that's the case for you, too, you might be better off just grabbing/building a new PC and the original versions of the games you want to play. It would be faster, more compact, and more energy-efficient.
If you want a general-purpose computer, I second the suggestion of a Mac Mini.
Unknown_K
I would say a single processor G4 Quicksilver would work. Preferably a 800 or faster (733's came with no cache and are slow).
Super cheap bordering on free.
Used AGP cards which are inexpensive and easy to upgrade if needed.
Is a screaming OS 9 machine.
Not too noisy and should not overheat.
Can dual boot to OSX 10.4.11 (which can use a cheap USB2 card while OS 9 cannot do anything but USB 1.x).
Only drawbacks would be to make sure the PSU is working. Even if the unit is missing a HD/CDROM and RAM those are super cheap to source (standard IDE and PC133 RAM).
Bunsen
Admin-Witchfinder-General
I would have said the G4 Mini, but they don't boot OS 9 IIRC :/
The ATX conversion is relatively easy, but rules out ADC monitors and bus-powered Firewire devices, as it doesn't supply the +24-27V line required.
TheMacGuy
G4 Mini can run Classic via Tiger, but not natively boot OS 9.
For Tecneeq: for everyday use I would choose the current Mac Mini. Low power consumption, hardly any fan noise.
For gaming, the Sawtooth Power Macs. But if you want both in one computer, a QuickSilver would probably work best.
uniserver
This is what i would say,
I'v wanted to respond to this thread many times, but I wanted to gather my thoughts first.
Even in Single cpu 733mhz Quick silver is a very powerful machine, My friend told me when he first got his 1.25 G4 mac mini, when rendering audio the Mac mini was just a hair faster then his 733 Quicksilver, Witch disappointed him greatly. I ended up over clocking that mini to 1.58 for him, witch greatly increased his render times. but anyways.
I suggest:
The QuickSilver Powermac, I was extremely impressed with the Dual 800mhz quicksilver when i had one, it was so sickening fast.
I remember it installed tiger in like 5 minutes. The other machines took 10 to 15 minutes.
Or the:
MDD Powermac, Just make sure you stay away from firewire 800, if its a MDD and it has firewire 400 then you are good to go!
Then you can have the best of all the (native booting) worlds. You can still smack pretty nice video cards in those as well… and they are right now at the lowest price they are ever going to be, couple years from now, I think the collector value/price on those is going to go up!
However for space-
Energy consumption-
The best you can really get , that still will boot MacOS 9 natively is: /w a USB 2.0 Card Bus.
http://www.everymac.com/systems/apple/powerbook_g4/specs/powerbook_g4_1.0.html
tecneeq
It's really just for OS 9. I have no interest in Classic nor OSX. Gaming isn't even it's main purpose, but i thought it would be the most demanding application i would ever want to run. I want a fairly silent and reasonably fast OS9 box for the next two decades.
The 1.25 MDD isn't my best option, it seems. Right now a Quicksilver with 800 or more MHz appears to be what i want.
And thanks for all the input, it helps a lot. :approve:
beachycove
For long term purposes, it should be said that the Digital Audio machines were probably more reliable than were the Quicksilvers.
Mind you, an iMac might do it in more style.
ClassicHasClass
Ignoring Cory, my gaming OS 9 Mac is actually a Power Mac 7300. It has a 800MHz Sonnet G4, a Rage Orion and a GB of RAM, plus two 7200rpm SCSI drives and a 24x CD-ROM. This plays great old games like Deus Ex, System Shock, Bugdom, DOOM, Unreal/Unreal Tournament, Voyager Elite Force, Dark Forces, Duke Nukem 3D, Pro Pinball, Oni, Carmageddon, Descent I/II, Quake I/II/III, Wing Commander III, Shogo MAD, you name it (yes, those all have Mac OS ports; there's a lot more where that came from). Stick in a USB card and use your favourite mouse, though I just use an ADB one. I ripped all the CDs to the hard disk and just mount them as images; only a few won't run that way.
I also stuck an OrangePC 620 in it with a 400MHz K6-III, which boots Windows 95/98 for specific titles. (For DOS games, I have an Am5x86 with ISA, which seems to run certain EGA titles better.) The only glitch here is that the OrangePC software does not like the G4 card unless I disable both the L2 and L3 caches; it does seem to be fine with G3 cards.
As a gaming card, I prefer Rage 128s to Radeons even though the Radeon is usually higher performance because they also have a lot of graphics glitches in some early 3D games that were never patched. Shogo MAD, for example, displays totally bogus polygons until you apply a Radeon fix, and Quake II never got repaired (so on my Radeon 9000 MDD I have to play it in software rendering or the graphics glitches become unmanageable). Obviously pure software-rendered games don't have a problem but there's not much rendering advantage then either.
I prefer to use my MDD for heavier OS 9 crunching tasks like Virtual PC or CodeWarrior. Relative to the MDD, the 7300 is smaller, more reliable and generally quieter, though the OrangePC card and Sonnet G4 have their own cooling fans (but nothing on the MDD wind tunnel howl). But you have to do some upgrading to get it to the point where it does well, and that will certainly cost more than an MDD, or even a DA G4 or Quicksilver.
