More trouble than it's worth..!One thing i've always wondered is how hard it would be to write some software that allows you to put one of those things in a PC, in order to emulate a G3 Mac. [}] ]'>
Well, technically, the 7200's Hardware Developer Notes say that it can take a 256MB DIMM, so having twice as many slots doesn't really give the 7500 a higher RAM capacity in theory.Back in the day, for not much more than what a 7200 would cost, you could've gotten a 7500, which has a processor mounted on a CPU daughtercard, and twice the RAM slots, and is basically a much better machine.
The 7300 uses a slightly different connector on the power supply.To the trash heap it goes.
I'll keep the power supply as a spare for my 7300.
Okay this one is way out there, but...Technically, all he's throwing away is the motherboard, which isn't worth much anyway even as a functioning board. Better to either replace the 7200 motherboard with one of the other 7x00 boards or a G3 board or to recycle whatever parts are salvageable into another Mac.
Because the AMP made CPU socket is no longer available unless you order over 1000 of them so it is worth it to AMP to do another run. And that information is about eight years old, so it may not be available any more period.Hmm.
Why just a second CPU socket though? Why not any CPU socket, with a pass-through for the CPU?
The CPU socket soldered to the S900 board accepts a finger-edged circuit board. You don't need a socket in order to plug into an existing socket. You just can't get new sockets to put on new boards, without spending a small fortune.How do you intend to plug into the socket then?
