WGS 9150: Crescendo + HPV possible?
Trash80toHP_Mini
NIGHT STALKER
Heh, you've got images of WGS 9150 dancing around in my head, thanks a lot! ::)
Meanwhile, on the AWS 95 full height NuBus/PDS tangent:
Sure looks like a tall if not full height NuBus spec. compliant PDS card to me.
Pics in a few.
Trash80toHP_Mini
NIGHT STALKER
The Apple Workgroup Server PDS Card stuff isn't really much of a tangent. Is the PDS slot placed inline, interfering with a NuBus slot as in the other Quadras? Did the PDS have its own dedicated cubic? That card made me wonder if there was ever such a full height NuBus spec PDS card for the WGS 9150? That would be a very cool thing to find indeed, even if only in a picture.  :approve:
OK, here goes.
These two show the mockup very roughly as in the Service Source exploded diagram.
The three slot PCI riser represents the top three NuBus Slots of the 9150. The cardboard PCI risers represent cards in the next two slots down.
You can see how the adapter overhangs the top slot:
One concern would be clearance between the VRAM SIMMs on the HPV card and the solder side of next NuBus card down given its offset position:
For background reference:
A pair of these inexpensive 1U risers could easily be hacked up to test in an open air setup. There would be unused connections for the short section of the HPV edgecard connector in that config.
However, straight line line traces/connectors won't do. Setback as on the NewerTech cable would be required for clearance as in the recessed card cages of 6360/5x00 adapters and 6400/6500 two slot adapters. IIRC even more setback is required for the TAM? The adapter needs to position the HPV card's video connector far enough back into the case to make an internal connection to be hooked up to a video connector on the backplane cover plate of the HPV card.
Anyway, the adaptation looks doable if and when. If the lid's card supports can be reversibly removed, no biggie. But if not it could take a bit finagling to fit the HPV card up in between the forks. Setback amount would need to be far enough for VRAM SIMM clearance, but it doesn't seem to be an issue from what I can make of that Q950 lid pic.
Thoughts?
jeremywork
Yes, the plastic lid spacers are individually removable. Your mockup is wonderful! Helps me understand that you're correct, removing the Nubus support from the lid for slot #2 only should perfectly accommodate for the HPV on a right angle like that, supposing the offset is still less than a "full height" card. I had pictured trying to stretch the cable to fit it this way and save the fourth slot, in which case we'd need to rework the Nubus card brace:
btw, the 950 uses the same PDS/Nubus inline as the other Quadras with PDS, and yeah the WGS Pisces card would have the top Nubus slot blocked and require the spacer removed from the door.
Wow this thread blew up all of a sudden, thanks for your interest!
I have ZERO parts right now, no 9150, no Crescendo, no adapter, no HPV card. I was just wondering if this kind of setup was even possible. I have a big gap in my collection at the moment between the 950 and my G4 Quicksilver. The 9150+G3/HPV would be the ideal machine but I'm afraid it'll take years or even decades before I can piece it all together.
That said, we can certainly start making some mock ups and it's only a matter of time before those flex cables crumble away.
I've had this similar idea bouncing around my brain for a while, but likewise I'm short a 9150. The rest I have in my working inventory though... One NewerTech G3 with HPV cable soldered on, Two Sonnet G3s and a G4 (which I'd probably use for the 9150) though only one Sonnet HPV ribbon cable. If it turns out we can use the 7100/8100 stock cable without modifying it, then cloning it would be a good benefit to x100 G3 owners and the small handful of 9150 dreamers out there. It'd end up more of a vanity project if the 9150 needs a custom layout, though. I've got a couple 8100s and a few 950s, so I'm using a mix of both as mockup reference for now :)
Trash80toHP_Mini
NIGHT STALKER
Last thoughts for the night: moar NewerTech integrated cable love! [:D]
Remove every one of those dagnabbit NuBus card support modules! Angle the HPCard up into the overhead and over across the four NuBus Slots. Some hot air cable rework required. All four Nubus Slots available, more or less. The Card in Slot D nearest the PDS may need to be a tad on the short side? Maybe some addl. hot air rework cable flexion? Dunno, total rise and run of the shed roof limited by case dimensions.
The most simple solution would be to just slice one of the bad cables off a G3 Card in my box of NewerTech G3/HPV goodness. Very handy header pin connector array available on the solder side of the card that is used to nail the cable to the board. A vertical riser adapter would be soldered to the pins and the card positioned. much like this:
You'd want to fab a lower level NuBus Card retainer bar for the lower cards and support for HPV and G3, but it's more straightforward/KISS compliant than rigging a shed roof and a way to redeem yourself given a hot air meltdown event.
Me, I'm done with this box and sticking to my fave, the Big Metal Can from Radius, Three NuBus Cards, G3 and HPV nestle quite comfortably in there. The clones are a lot more available and the 81/110 has got to be a lot less expensive than WGS fantasies.  :approve:
jeremywork
This was my first supposition- is there enough cable to safely loop it over itself? Looks physically possible from your photo (and hot air assistance is a good idea) though there are no other Nubus cards to collide with either.
9150s are rare enough that it's a pipe dream, but I would take the shot if an opportunity arose. If one could retain four Nubus slots in addition to HPV/G4 that'd be pretty sweet. The /120 model will also have BART21, so potentially the second fastest/most complete Nubus Apple shipped, behind the 840AV's. The 8100/100 I already have isn't far behind, and would be theoretically identical if I clocked it at 40/120MHz, minus one Nubus slot.
Removing all the door spacers is easy, and then one approach to securing cards is to install a vertical metal bar along the back case, pressing up against the metal Nubus i/o shields at the back of the cards. Unclip the bar to swap cards, and reinsert the bar before closing the case.
Trash80toHP_Mini
NIGHT STALKER
I've got a couple of the Sonnet sets somewhere around here, but I don't think they'll work with a card in the adjacent Slot D.
That edgecard connector is but a few mm shy of the Little Red Riser,and then you've got to make the cable turn up with the PCB pretty much against the solder side of the Card in slot C. At that point it's a tossup as to whether there's enough flex in the the remaining cable length to do the 180 loop high enough to clear the top of the cards in the remaining 3 NuBus slots
Fabbing a riser PCB to solder smack onto the headers holding the cable to the backside of a NewerTech G3 Accelerator is really the only way to go with some semblance of  .  .  .  :blink:
Doing it that way ain't elegant, but it's the only way I see to retain all four NuBus slots.
Trash80toHP_Mini
NIGHT STALKER
edit: Page 2, HEH!
Rare enough doesn't quite say it. Here's Cameron Kaiser's WGS 9150 page: https://www.floodgap.com/retrobits/ans/9150/
He hasn't gotten back to me about posting a few of his pics here for illustration purposes, maybe later, meanwhile check 'em out.
I fail to see how the stock 9150/80 could be considered slower than an 840AV? If you're saying the code base was not yet up to making full use of the 601 while they were barely contemporary, that's one thing. But the two PPC Macs are clearly better packages and faster if not equal in overall machine0. Even your 8100/100 should fare better running proper code. The Quadra 840AV ain't really all that outside of the 68K arena.
VRAM is 1/2 or 2/4 on the HPV variants so that's no contest for your 8100 though not a standard feature on the 9150. System clock is equal for the 9150 and Processor clock doubles, 9150 has four times the 840AV's L1 Cache and 512k of L2 where the Quadra has none. Same is true of you 8100 with the fastest CPU clock of the three. The only place your 8100 lags would be System Clock and the 4x L1 bump and addition of 256k L2 should make up for or slightly better the Quadra's best in overall performance. The 33MHz-40MHz jump that made the 840AV so fast as compared to its 33MHz predecessors wasn't all that important once you moved out of the realm of unified bus architecture and into the world of Front Side/Back Side buses. The DevNotes call that the Processor Bus and Slow I/O Bus which debuted in PowerBooks/Duos. I don't recall a stationary 68K machine with a split bus offhand? Does anyone?
Now, unfortunately I'm even more interested in the 9150. With that fourth slot available for an extra striped JackHammer array, did the 9150 even have a need for the likes of the Apple Workgroup Server 95 PDS Card, given performance of contemporary HDDs?
Neat stuff! Who's keeping an eye out for one? :lol:
jeremywork
Not the machine's performance as a whole, but the maximum Nubus performance. Apple's BART chips tie the 601 bus to Nubus, and it's not done quite as efficiently as the 840AV's Nubus 90 implementation. ATTO SE IV scores are more like 16MB/s on my 8100, where 840AVs will get over 18MB/s.
Radius VideoVision documentation calls this out, claiming the 9150/80 is identical to the 8100/80, and both are slower than the 840AV: http://archive.retro.co.za/mirrors/68000/www.vintagemacworld.com/radius/vvision.html
Furthermore, there's a bug in the initial PPC BART chip (BART4) which disabled slave block transfer on all cards unless every card supports it. BART21 corrects this flaw, allowing fast cards to be fast while slow cards exist. The only Apple-shipped machines confirmed to always have BART21 are the 8100/100, 8100/110, and 9150/120: http://radius.vintagebox.de/Support/dv/Bart.html
The WGS pisces card wouldn't install in a 9150 without an 040 PDS slot, however the 8100 introduced the second Fast-SCSI II internal-only bus (10MB/s over 5MB/s standard- not quite fast & wide but better.)
The 7100 didn't have this but I'd be quite surprised if the 9150 also didn't, especially considering the 950 before it already had two SCSI busses (though not different speeds.)
This was a fun read, thanks!
Unknown_K
The WGS 95 card with cache is nice but there is a rare PDS SCSI card for the 950 that is probably much faster then anything Nubus.
I wish I had a 9150, missed out on one in Ohio a decade or more ago and never seen one since.
Trash80toHP_Mini
NIGHT STALKER
Yep, that PDS is card is 33MHz in the 950/95 040 PDS whereas the HPV/G3 PDS bus is 40MHz.
I wonder what that gem looks like? PDS is a fatter pipe, but a pair of JackHammered Fast/Wide RAID setups (with redundancy) would have be fine for a 9150 with the HDDs of the era on that pair of NuBus slots? If the SCSI Controller ICs on the PDS card were no faster than the JackHammer's, and there's little reason to think they would be, PDS might not make that much a difference? Dunno, I can only fit the one JackHammer in my Radius 81/110 along with VideoVision and Thunder IV GX/1600. With the G3/HPV combo tucked in there as well I'm very happy indeed. Besides, who really needs that fourth 9150 slot and a second JackHammer? Anyway, I've pretty much been a Radius collector from day one when the spankin' new SE/Radius16 arrived and I started drooling on the Radius FPD ads in MacUser.  [:)]
jeremywork
Are you referring to the MicroNet Raven Pro or Storage Dimensions Data Cannon?
IIRC MicroNet claimed 17MB/ throughput in their marketing, which should be even faster with modern drives. Theoretically still in the same class as an 840AV with SE IV or Jackhammer, but without needing to share the bus the real world performance should be noticeably better. Too bad the 950's un-cached memory bus seems to only move 10-12MB/s in my experience. With your 50MHz/128k unit it should be much happier.
I dropped a bunch of 950 memory benchmarks over here the other day:
Trash80toHP_Mini
NIGHT STALKER
Well after a bit of under the bed diving, I'm suddenly back in the 10-ring of the topic!
We're talking silly millimeters in width and height for the possibility of 4-Slot 9150 glory. Oh so very very close a run. Hot air rework not done, but necessary. Height should be good, the PCI risers slots are sitting higher than the PDS/NuBus backplane.
jeremywork
Height looks very promising, but yes that initial bend at the Crescendo will be brutal.
Luckily after doing some rough measuring on that 9150 prototype photo it seems that the PDS center is slightly further than the nubus cards are to each other. Good news for this idea...
I just copy-pasted this green line three times, so all of them are the same length, touching center to center of each Nubus, but only reaching the outer edge of the PDS.
Trash80toHP_Mini
NIGHT STALKER
I looked at the same thing, but you're measuring connector to connector. You need to estimate PCB to PCB spacing, which makes them more or less equidistant to my eye so I didn't go to the OS9 graphics bubble of the QS02. PDS is centered in its edgecard connector while the NuBus card PCBs would bea at the very top edge of the outside of the EuroDIN connectors. Proof of that is to be found in the even spacing of the five Backplane slot covers.
jeremywork
Ah I overlooked that, which would perfectly explain that spacing. At least it's not *less* than standard width :)
jeremywork
Okay- super wacky idea...
Can the PDS riser be used before the Crescendo? Stick the HPV directly into the Crescendo upside-down in slot 1 and run the ribbon back to motherboard PDS?
________________
|        _...-----.._
|---""  ________| (G3)
| (Slot 2) (^HPV Slot 1)
| (Slot 3)
| (Slot 4)
| (Slot 5)
Trash80toHP_Mini
NIGHT STALKER
Dunno, not sure my eyes are tracking together on your nice ASCII graphic. Pretty sure I blew up one my fancy Sonnet Cables trying to us it as a generic PDS extender? Memory is fading out due to attitude adjustment/manic wind down session for the night. Spent much of the evening opening up, going through piles of mail, sorting and organizing the storage container layers into a wonderfully compacted format. IOW, what I use for a brain's mostly offline ATM. :blink:
jeremywork
Unfortunately ASCII's a bit low res ;)
Picture the Crescendo and HPV installed properly in a 6100, then imagine flipping the whole assembly upside down and inserting the top of the HPV into the bottom of the 9150's HPV slot- then use the riser to connect the Crescendo to the motherboard PDS (unless your experience with this is bad news)
Trash80toHP_Mini
NIGHT STALKER
Yea, I tried something like that, I don't think it's healthy for cable or accelerator given the logic on the cable. We'll have to wait for @Bolle to chime in on that one, but it's just a matter of curiosity. Methinks I've been overthinking the problem.
The NewerTech cable positions the HPV overtop and at a right angle to the NuBus cards in the generous headspace of the 81/110. The Sonnet kit can place the HPV card in the generous floorspace of the case parallel to the third NuBus card. Cable length precludes that solution for the 9150 because of the fourth NuBus slot even if it had the required floorspace. The NuBus card's component sides face down in the 9150, so it doesn't appear to have the required floorspace in the exploded diagram.
So I've missed the most simple solution for the 9150 while target fixated on adapting known solutions for my clone. The answer was sitting in the pictures above all along as a rough reference point for slot spacing. The WGS 9150 needs only to be equipped with a machine specific Twin PDS slot riser card. ::)
Du'oh! [:I] The way I'm seeing it now, the setup has some fairly simple aluminum angle and bar construction to hold the two PDS cards in position. Provision can also be made for holding the NuBus cards in place in the manner of the removable bar in my 81/100. Add power headers to the riser and mounting points on the aluminum support structure and a fan is positioned inboard the riser for cooling. Such might approach the most elegant of Rube Goldberg bodgery.
I've got riser like the single slot card with a second slot above the first. That would have made for a clearer example, but couldn't find it. The cabled riser is an off the shelf PCI plaything. A pair might be hacked to do the job, which would be truly Rube Golbergian. But it roughly approximates the height of a WGS 9150 PDS TwinSlot Adapter.
There, now I can start storing this cruft back in place.
Franklinstein
So I actually have a 9150/120. It's pretty beastly, just as imposing as a Q950 but with a few external changes that modernize it to more closely match the styling of the 6100 and 7100, including the relocated and now manual-inject floppy drive whose original home is occupied by a new CDROM (the former tape drive bay is still available for use if not occupied; mine's empty). These were one of those rare machines where it was available only as a WGS without a workstation counterpart. You could sort of count the WGS 95 in the same category since its special WGS cache card was unique to the server model but otherwise it could be configured as a workstation whereas the 9150 could not. Incidentally, as was the custom at the time, the 9150 logic board was offered as a drop-in replacement for the WGS 95, which makes it the only NuBus PPC model to use a DB15 monitor connector in addition to the fact that it keeps the Q950's audio in/out ports. Both the 80 and 120MHz versions ran the bus at 40MHz which was really fast at the time, with the 120MHz version being that much faster than the "flagship" 8100 which topped out at 37MHz in the 8100/110. Plus these could be configured with up to 1MB of L2 cache, as could the WGS 8150. Also, these are the only machines I've seen where the PDS terminator is required if the slot is unoccupied whereas all of the other NuBus PowerMacs don't care if the slot is empty or not. Why Apple didn't sell a PM 9100 is beyond me but they did all kinds of crazy crap for stupid reasons back then so who knows? They already had to build the "Fat AMIC" to accommodate the extra NuBus slot so I'm not sure why they didn't make a few more improvements to perhaps double the number of RAM slots; they had more than enough empty board space to do it.
Anyway there's really no way to use both the G3 PDS card with an HPV card and all 4 NuBus slots without either hacking up the case or using a custom cable that passed through the case and was connected externally; there's just no room in the case to do it cleanly and you'd need to build a new cable anyway. Thus, with either option you'd need a custom high-grade cable and precision workmanship to prevent signal problems since this is a high-speed bus connected directly to the processor. Maybe it would be possible to repurpose an Ultra320 SCSI cable or two? Those are built to handle high-speed data.
