Hi everyone,
Since I couldn’t find a 350+ MHz G4 for cheap for my Beige G3, I decided to make my own.
I own all kinds of soldering supplies and I have some BGA soldering experience.
Bought a 300MHz G3 (comes with 1MB L2 cache able to run at 2.8V) and 5x MPC7410 450Mhz.
From what I gather from here: https://datasheets.su/DS/NXP/MPCPCMEC.pdf
I should be able to lower voltage using the resistors to 1.8V (even so from what I can see on the ZIF module it should be set to 2.05V which is still supported by the MPC7410?).
As for the L2 cache, I should set the voltage to 2.5V, but I am not sure how.
The cache should come set to 3:2 “Late-write”, is that better than a pipelined 2:1 cache ratio?
So summing up:
1) Will anything blow up if I just swap the MPC750 for the MPC7410?
2) How do I change the L2 voltage? From what I can see the MPC7410 can’t operate L2 at 3.3V.
Hopefully these infos will be useful to other members as well. Tagging @dosdude1 since I know he has a lot of experience in these things.
If I can’t find any infos I was thinking of measuring Vcore on the BGA pins before soldering the new CPU in while messing with the resistors. Worth a shot.
Thank you for looking!
So summing up:
