chrisrueckert
I am looking for a replacement of my defective PSU for the TAM. Ebay lists PSUs with similar part numbers but I am not sure if these are also suitable for the TAM. The OEM part number is dps-150gb-1 A, that Apple part number is 614-0057.
What options are there to be used as a replacement from your experience?
PS: Yes, I fried it because I did not change the voltage switch to 240V. What a firework...
