TheMightyMadman
Hi all,
The power supply has unfortunately died in my Macintosh Performa 6400 - it won't start up at all.
It is a 150W unit, Apple part #614-0060, Delta model number DPS-150GB B.
The PWM controller (TOP200YAI) had failed dead-short across all pins. I'm not sure whether this was the cause of the fault, or just a symptom. I did some basic checks on all of the other actives, and they seem OK in-circuit, and the two output rectifiers (STPS3045CP) seem OK out-of-circuit.
I swapped the PWM controller for an uprated part, but the unit is still dead.
Does anyone have schematics for this or a similar unit, please?
Failing that, does anyone have any advice on how best to go about diagnosing it?
Many thanks,
Adam
Many thanks,
Adam
