Does anyone know if there is any kind of replacement AirPort card that allows the TiBook to do WPA2?
K kb3wmh Well-known member Mar 21, 2015 #2 Does anyone know if there is any kind of replacement AirPort card that allows the TiBook to do WPA2?
TheWhiteFalcon Well-known member Mar 21, 2015 #3 I think you'd need to look at something for the PC Card slot, and not something to replace the AirPort card directly.
K kb3wmh Well-known member Mar 21, 2015 #5 I see it, and probably should have looked at it before starting a thread... Thanks for the help!
K kb3wmh Well-known member Apr 19, 2015 #6 Solved my own problem... I have a USB Edimax EW-7811UN wireless adaptor. While looking on the website, I found that they had Tiger drivers. I installed that and am now happily (though quite slowly) on the web!
