It makes no difference to the download what the suffix is. If you mean that you can decode StuffIt files (.sit) files more easily, go to your StuffIt Expander preferences and make sure that '.bin' is enabled. StuffIt can expand either filetype, and many more, if it is configured to do so, which is usually by default for commonly used compression/coding methods.
de
